964 Forum 1989-1994
964 c4 2 problems
Old 02-21-2009 | 02:42 PM
avvrobin's Avatar
avvrobin
7th Gear
Default 964 c4 2 problems
hello guys im roby from italy.
i have a splendid c 4 964 1989 k . white i have 2 problem :
1)clima's temperature sensor is crazy, dont stop more.
2) in 5^ speed from 180 km to 210 there's a vibration on gear shift level. if touch the lever the vibration there isnt. the sound is like tic tic tic tic .
thank you, regards
Old 02-21-2009 | 08:26 PM
Indycam's Avatar
Indycam
Hi Roby
#1and #2 problems , I don't understand , can you ask again with more words ?
Old 02-24-2009 | 11:14 AM
avvrobin's Avatar
avvrobin
7th Gear
dear indy,
im happy to talk with you, sorry for my english!
the first problem, about clima it has been resolved.
the second problem: when I run in 5 march, is a vibration on the shift lever, sound is tic tic tic. if i hold the lever the sound there isn t.
the vibration there's only from 180 to 210 kmh.
thak you
Old 02-24-2009 | 12:05 PM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Just thinking out loud here...
Vibration on the shift lever can be from many sources. I am guessing it is pronounced since you feel is not a normal vibration.
The shifter slides over a pipe that is held in place with two rubber bushings and two clips. If these deteriorate you will have more than just vibration...
Do you have the stock engine mounts? It could also be that engine mounts have gone bad and are transmitting vibration... but it would do so along the rev range... not just at a certain speed...
Are you sure that that vibration comes from the shifter and not tires that need to be balanced? But those would manifest all over the car... humm...
Old 02-24-2009 | 03:46 PM
Indycam's Avatar
Indycam
Shifter linkage bushing and such are worn ?
Old 02-24-2009 | 04:40 PM
avvrobin's Avatar
avvrobin
7th Gear
you have an incredible know how about this car !
compliment .
the tyres is good, because i have two tyre's train. for winter and summer
always pirelli . the cluch is new . i hope
thank you for all .
Old 03-23-2009 | 12:43 PM
avvrobin's Avatar
avvrobin
7th Gear
Dear Wachuco,
im avvrobin from italy, do you rember ( the vibration on manual trasmission contol of 964 c 4) .
I have read your answer, and have taken apart the trasmission manual control, with great surprise I have not found bearing sleeve and circlip (n° 26, and 28 on PET porsche n° parts 96442422401). as I can mount it.
because the bearing sleeve is a oring. is easy to mount the pipe or central tube to introduce the oring ?
thank you for help me.
regards
Old 04-28-2009 | 03:37 PM
Wachuko's Avatar
Wachuko
Robert,
I received your pm, posting here in case we have other members from Italy that might be able to help and communicate better in Italian... I am learning Italian but it will take me years before I can speak it or write to make any sense...
You mentioned in your PM that the vibration is back.
We need to narrow down where the vibration is coming from...
Clutch
CVJ - drive axel cuscinettos (ball bearings)
Is the noise the same when you disinnestare la frizione (disengage the clutch) ?
ciao a presto,
Jaime
Old 04-28-2009 | 04:01 PM
avvrobin's Avatar
avvrobin
7th Gear
dear ,
your italian is better than my english.
i haven t double mass clutch but more simply sigle mass.
and i have changed the rubber disc.
i suppose the problems are in bearings *****. is possible to change em into the central tunnel? because the mount engine and trasmission is ok.
i saw in rennlist forum in search vibration trasmission many important discussion.
thank you
Old 04-28-2009 | 04:21 PM
Wachuko's Avatar
Wachuko
I know you keep coming back to the central tunnel bearings... but have you checked the CVJs? (Constant Velocity Joints). These are the bearings in the drive shafts (transmission to the wheel hubs).
If they are bad they can give you drivetrain vibration like the one you describe.
I have never taken out the torque tube (central tunnel) in the 964 but I always thought that failure in the torque tube was rare... more common on 944 (this one I have taken out a couple of times when replacing the clutch in my 951) and 928 than in our cars.
Quick Reply: 964 c4 2 problems
