964 Forum 1989-1994
engine RPM question
Old Jan 16, 2009 | 08:34 PM
Boeing 717's Avatar
Boeing 717
Registered User
Default engine RPM question
Hey guys i put this on the turbo board but will ask you guys as well........when i lift off the throttle to switch gears, it "seems" like it is taking a lot longer than it used to for the revs to come back down. Almost as if i had a really heavy flywheel that kept the engine spinning. i dont think its my imagination but it could be. Is there some sort of adjustment that could be out of whack, i think there is an "overrun" diaphram but i dont know if that could be it. I did notice that my throttle pedal seems really sensitive and may need to be slackened a little perhaps causing this.
Old Jan 16, 2009 | 08:40 PM
Geoffrey's Avatar
Geoffrey
check for vacuum leaks or a bad idle air control valve.
