964 Forum 1989-1994
ABS Light
Old Dec 29, 2008 | 06:05 PM
pat056's Avatar
pat056
Default ABS Light
My ABS light is coming on my C2 after the car reaches the 4mph point. I did the usual of replaceing the relay and fuse. I have a reset switch, but as soon as I reset, the light comes right back on. It doesn't come on when I start the car or reverse it, only going forward. I'm hoping it's just a dirty sensor. Does anyone have any good pics or speecifics on how/what to check clean? I'll be working on it at 1st light tomorrow, so any help would be appreciated.
Old Dec 29, 2008 | 08:04 PM
dfinnegan's Avatar
dfinnegan
Here's what I've gleaned about ABS and PDAS lights/problems from various sources; mostly Rennlist.
Code:
    ABS/PDAS
      Clock Cold Solder Joints - re-solder both sides of the board
      Front boot crash sensor connectors
      Clean Accelerometers
      Clean wheel sensors
      ABS Relays - both?
      Alternator - if going bad may provide low charge and cause lights
      Check battery voltage - low voltage causes strange problems
      Check PDAS control unit connection
        unit is mounted wrong-side up so moisture sits in connector and rots it
      Check pressure switch seal (C4)
      Fuse 15, Relay 51 - maybe just replace these
      Ground wire behind pressure switch plug (C4)
      Adjust brake fluid reservoir level - few ounces +- can make a difference
      Bleed longitudinal and transverse locks (C4)
      Check ABS power connection at battery
        - it's a piggy back and the nut comes loose
        - connect gets corroded and shows intermittently
      Main ECU connection pin 26 dirty
      Loose wheel nut caused toothed gear to move giving false signals
      Check grounds in front trunk
      Check Adrian's book
Old Dec 30, 2008 | 05:46 AM
kalujo's Avatar
kalujo
pat056.
Had a similar problem with mine,went through all the items on the list posted by dfinnegan,with no positive results.Then whilst checking the resistance between the terminals on the main ECU,(again nothing positive).Then when I plugged the ECU back in ,hey presto,the lights went off.I figured that I must have been getting a bad contact on the ECU,on inspection all looked OK.But with pokeing around in the terminals with the tester,it squeezed the terminals tighter.
Its worth a try,and costs nothing.
Best of luck!Let us know how you get on.
Marc.
Old Dec 30, 2008 | 06:38 AM
ThomasC2's Avatar
ThomasC2
cleaning the connectors is easy. Just pop-open the black plastic cylinders on the hub/damper, pull apart the connector and clean with 5-56 or similar. Also check the brown ground cable on the wheel hubs/carriers.
Old Dec 30, 2008 | 08:29 AM
pat056's Avatar
pat056
Thanks guys!
Old Dec 30, 2008 | 09:52 AM
boxsey911's Avatar
boxsey911
You can pull the speed sensors out of the hub after undoing a single hexbolt. Clean away all the gunge and filings with electrical contact cleaner and vacuum out the holes before replacing.
However, I cleaned all four because my ABS clearly wasn't working (wheels locked) yet I didn't get a warning light on the dash.
Old Dec 30, 2008 | 12:57 PM
elbeee964's Avatar
elbeee964
Originally Posted by boxsey911
...However, I cleaned all four because my ABS clearly wasn't working (wheels locked) yet I didn't get a warning light on the dash.
(I hate it when a good story suddenly stops and leaves you hanging...)
And?... and???...
All was right afterwards?
Old Dec 30, 2008 | 01:31 PM
boxsey911's Avatar
boxsey911
And?... and???...
Sorry Lonnie
Yes cleaning the sensors worked wonders for restoring the ABS function to the car.
What I was trying to point out to the OP was that, strangely, I had no warning light to tell me there was a problem (it was the skidding that did that ). Therefore, cleaning the sensors might not help him - my guess would be a break in the circuit somewhere - I heard of story where the cause was a break in the loom between a sensor and the ABS unit.
7 Porsche Models That Have Aged Like Fine Wine
Old Dec 30, 2008 | 01:54 PM
pat056's Avatar
pat056
Not such good news for me
I was suspicious my problem could be the battery as mine was completely dead. So I got a new battery. Then:
I topped off my brake fluid to max,\
Just cleaned all the sensors (not a bad job BTW) and cleaned all the connections. Not very dirty.
Checked my wiring and found/repaired an exposed place
Started the car, backed it up, and as soon as I stat moving forward, the ABS light comes on.
Oh well, I now know several ways not to fix my ABS
I'm not sure how I would check the electricals since it only comes on when I'm moving forward.
Old Dec 30, 2008 | 03:35 PM
dfinnegan's Avatar
dfinnegan
It seems interesting that rolling forward (only) at 4mph turns off the spoiler warning light.
Could it be clock related? Cold solder joints? Try cleaning the connector for the spoiler control unit?
Coincidences are suspicious.
Old Dec 30, 2008 | 05:41 PM
pat056's Avatar
pat056
My clock and spoiler control unit have been disabled since I had the car. My guess is they were disconnected by Synergy (then G&W) when they built the car.
I will look at it though. I've changed the ABS relay and the fuse. I was thinking my problem may be that when the car was moving fast enough for the ECU to recognize the sensors, maybe it's not getting an input? How do you tell if a sensor's bad?
I'm no electrician, but since I'm not working now, a penny saved is a penny earned so I'll keep looking.
Old Dec 30, 2008 | 09:08 PM
HAB5000's Avatar
HAB5000
Sorry Lonnie
Yes cleaning the sensors worked wonders for restoring the ABS function to the car. .
Great to know,Thanks.
I have exactly the same problem - no ABS, no warning light.
Old Jan 1, 2009 | 10:56 PM
Dr Strangelove's Avatar
Dr Strangelove
I recently had a similar problem and cleaned the contacts. I then reset the fault using the Hammer. At least in my case, I don't think cleaning the contacts alone would actually get the light to go off.
-Bruce
Old Jan 2, 2009 | 05:56 AM
ThomasC2's Avatar
ThomasC2
"It seems interesting that rolling forward (only) at 4mph turns off the spoiler warning light"
I had the same problem last year. It ended up with a really stupid mistake. I had cleaned all the electrical connectors for the ABS during the winter (the black plastic cylinders). And on the left rear wheel I'd mannaged to put the connector in the wrong hole. It's really easy to do when you have three holes in one of the connectors and two on the other. So you have more than one choice when you put them together. So the connector was only "50%" connected. Check this one if your not 100% sure.
Old Jan 2, 2009 | 09:06 AM
darth's Avatar
darth
"How do you tell if a sensor's bad?" There are a few ways to test the sensor in order of sophistication: 1 - ohmmeter to measure the resistance between the terminals. 2 - measure the AC voltage with an AC voltmeter tapped into the connector and measure while the wheel is moving. 3 - replace the AC voltmeter with an oscilloscope . One should be able to diagnose a bad sensor using 1, comparing resistance values to the other sensors. The sensor should be a contiguous multi-loop of wire around an iron core (i.e. that small rectangle protrousion pictured above) so any out of the ordinary resistance (i.e. when compared to the other sensors) values would be suspect.
Hope this helps
Bill
90C2
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
