Rear reflector/tailight tint: testimonial
#196
Bernard -
Looks great - Job well done - Did you take the lenses off because of the cold weather to work on inside ( warmer) ? How difficult did you find the job with the lenses off the car to put the vinyl on - what did you use to hold the lenses while you put the vinyl on? Just want to share with others as putting the film on in cold weather is not a good.
Thanks for your order -
#197
Bernard- damn over 1200 bucks!
I just received mine from Sunset Porsche 234.00 for R/L and 373.00 for the center= 841 for all 3
btw-I used the vinyl on mine a few years ago, it worked fine no issues. I just like the lighter OEM look better so I went back to it... and no I'm not selling my old lights gents
#198
Bernard -
Yes it was just way to cold in the garage to install the kit. I was also replacing the center reflector with a used one I picked up so it needed to come off anyway.
I worked on a cardboard box with plastic over it. What worked for me was spraying the solution on the tail light and film and laying it on the light and used my palm on both corners to stretched it out and placed it in front of a propane heat warmer for just a few second to dry all the solution out of the light.
#201
#202
Gus:
PM sent. Love the look on Ritter's car since his looks to be Polar Silver like mine.
#203
At this time Gus only does the film kit in the red tint.
I would like to try out the grey tint as on 911Jetta car (hope you don't mind me using your image)
https://rennlist.com/forums/attachme...09-nov-086.jpg
I have a spare set of tail lights and centre reflector that I want to try it on.
Gus does not want to buy a roll of film for just one order which I completely understand.
Is there anyone else out there that would be interested in a grey film kit?
If so please let Gus know.
thanks
thanks
#204
David / Lonnie - Thks for feed back and posted comments - I found this and thought that it would be a viable solution to our (964) pink taillight issue. I sent 4 test kits out - only got feed back from David and Lonnie - so slowed up a little - 1. Because it is now winter and the vinyl needs to be warm to do a good install 2. Was hoping for more feed back so I could correct any flaws or trouble areas in the kit. Lonnie and David gave great feed back - All vinyl is hand cut due to template design - Will more than glad to put kits together for anyone that wants one - Complete kit would run $ 50 - replacement vinyl is $10 for each side light and $20 for the center section. I will try to cut the verbal abuse down in new instructions. If interested PM me. Think Davids pictures say it best - It is an easy install if you take your time and work the vinyl. I have no long term est results as I put on my car early fall - about 4 months ago - Still look great -
I'm in Sydney Australia. If you do can you please advise of costs for 2 kits. Regards
Hughesy
#206
Hughesy- Ok looks like i can post 2 kits to you for $26.00 USD. So this puts total cost at USD $ 71.00.
YOU can make payment to my PAYPAL account - gustavwf@mac.com. Once I get verification of payment I will make kits and ship to you .
I will advise when I ship.
Please provide valid mail address and contact information -
G
G
