Headlight Repalcement
I have a '92 C2 Coupe. Saturday I was driving at night in the country and was very dissapointed with the headlight performace. Can anyone recommend a good replaement bulb? The manual is not very clear as to what the correct bub type is (H4 or H5 or?). My '04 Mini Cooper S has the Xenons and they are quite a bit better, but I don't think I want to convert to the Litronics, just hoping that the coorect replacement bulb will help. Any advice is greatly appreciated.
the H5 has little nubbins on them for alignment and the H4 does not
the H5 is a one fixture item including the outside ring while the H4 has a separate outside ring
the H5 is fixed while the H4 comes in a moveable verison, although most are fixed
the H4 can use quite a brighter bulb
a pic of the moveable type
Agent Orange
Cute Avatar Lonnie ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I believe the H5 bulbs were developed for the US market after the DOT changed headlight regulations in the 80's. H4's have a distinct cutoff and don't let any light above it, while H5 headlights let some light out above the cutoff. IIRC the idea was that with that extra light above the cutoff drivers would be able to see non-illuminated highway signs better. Or at least that's what I read. Just for the record, I've been able to see highway signs in the dark with the H4's just fine.
As far as putting brighter (as in higher wattage) bulbs - you can, as long as you wire the headlights properly with the corresponding relays. Otherwise you'll short your headlight switch and can start an electrical fire. Not good.
Here's a schematic that shows what you need to do to wire them correctly:
![](http://i189.photobucket.com/albums/z130/Slithering_Joe/TJ_HEADLAMP_RELAY_HARNESS.png)
Personally, I've been happy with my H4's and Silverstar 55/60W bulbs.
YMMV
YMMV
Thanks for the background.
And, heck -- join in on the festive seasonal ornamentation, Ilk!
("Many Happy Returns from Santa's Helper's leettle 'freind!")
![Name: avatar42451_27_christmas.gif
Size: 27.0 KB](https://rennlist.com/forums/attachments/964-forum/321663d1229531431-headlight-repalcement-avatar42451_27_christmas.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
