Distributor stuck
Thanks Garrett, that's EXACTLY the shot that I needed to confirm what I need to try. I've got a small crowbar like that and I think I'll put a small block of wood down there so that I don't bend anything while getting it out.
A crow bar is an elegant solution. I am sure Dr. Porsche would approve, and even offer you his own crowbar if you needed one. I have used it myself, and it works great. You can protect the castings with bits of wood if you are concerned about marks.
I went through considerable pain and concern reinstalling mine with a fresh o-ring. I suggest practicing the reinstallation procedure several times without the o-ring present so you get the feel of things. Once you put the new o-ring on, it will most likely be difficult to seat the dizzy. Use lube for sure, and be prepared to push much harder than you thought was necessary.
Finally got that sucker out and changed the belt this morning! After a bit of prying with the bar, it still wouldn't budge. Turns out that we actually got it to move just a bit and then was able to pull it out by hand!
Changing the belt was a breeze with all of links and help with Adrian's book. Thanks again guys, another maintenance job done!
