Bumper above Pipe Melted - Can I find Protector?
Does anyone know where I can find one of those aluminum protectors that go above the tailpipe to protect the bumper section above it from melting?
I've seen them here and there -
THanks in advance
THanks in advance
Agent Orange
Well I'm not qualified to answer that but... Is it melting the bumper on top or on the sides? Because the picture you have shows a piece of your bumper missing on the right.
Maybe you can tweak the position of the tip so it can point lower. Or call Ruf and ask them what they suggest. I'm sure they wouldn't make that piece if it would melt bumpers left and right.
Any after market tip if installed too close to the bumper will melt it...I did it w/a BB exhaust. Factory ones don't get very hot given the design...but I can tell you from experience, its a PITA to make a piece for that area. Plus as an FYI given you cooked it, it is now very brittle....so at some point it may split especially if it gets taped.
Check with your local Porsche dealer or Gert has them available at Carnewal.com: http://www.carnewal-europe.com/main.htm
I have the same Ruf tip and it is 1/8 - 1/4" from the bumper with the bumper still just fine. I think a closer look is neccessary to see if the bumper is getting brittle. Also have the Ruff bypass. Sounds Fantastic. Best heard yet.
I couldn' fine the exhaust tip shield @ http://www.carnewal-europe.com/main.htm
FlatSix911: If you have the direct link to the sheild I would greatly appriciated it?
I see I can't spell this time of night. I would power coat a shield black. Okay the search is on.
Chodaboy: Please let me know what your considering. Black would match our lower back bumper & rockers.
