964 Forum 1989-1994
1st gear clunk
Old 10-25-2008, 06:44 PM
sshenton1975
sshenton1975's Avatar
Default 1st gear clunk
Hi All
Took my C4 out for a fantastic drive today - all round South Wales for a good hoon - over 300 miles
Most I've dirven it all year and I absolutely loved it!
Only concern is that on the way back (last 50 miles), car developed a sort of "clunk" as I put it into 1st gear and let up clutch. I think it seemed to be coming from drivetrain.... Not too worried but definitely not there when I started
Could it be simply that the oil had got hot and thinner??
What are your thoughts?
No impact on the drivabaility. No slipping clutch
Old 10-27-2008, 04:13 PM
sshenton1975
Any thoughts on this guys?
Old 10-27-2008, 04:38 PM
DAVISRILEY
DAVISRILEY's Avatar
Does it make the same noise when you start car up, or shut it off? I have heard dmf's fail that way. Other than that, what year? If the car is a 1989, iirc it has a rubber centered clutch, and that could be coming apart. Good luck.
Old 10-27-2008, 08:38 PM
sshenton1975
Hi guys
My car is an early 89 so I am assuming it will not have the DMF?
Does not happen when I start the car - only happened after a long drive this weekend when pulling away in 1st - not affected in any other gears.
Think I may have heard a slight "buzzing" in 1st gear also up to about 3000 rpm?
Please give me the cheap possibilities first followed by new clutch later!!!
Clunk does seem to be coming from middle of car - ie in between seats/near shifter
Quick Reply: 1st gear clunk
