Suspension install questions
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Just completed this job myself.
Cutting that nut off had to be WAY harder than removing the three 13mm nuts...
I used a (shorter) RS bump rubber on my rears. Last defense from metal to metal contact if things go bad.
Was scheduled for alignment today but - get this - my Motive Brake bleeder blew a hose during the bleeding! Brake fluid at 12 psi squirting everywhere!![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I spent over an hour cleaning up the mess. Is synthetic brake fluid as nasty to paint as the old stuff??
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Funny you mentioned the hose issue… same thing happen with mine… at 20psi just when I had finished doing the last one...
Good thing my father-in-law was there and I had placed a towel under everything... no harm done... but now looking for a better quality hose to replace it.
Seems some of the replacement parts will take awhile to arrive... that and work related travel will sit the car in the garage for a few weeks...
Someone here had the bright idea of putting a pneumatic coupler in the line to the cap. I've adopted that idea and am very pleased with the result. Put the coupler close to the cap. That way, there is less air loss from each de-coupling. And, you get a whole new hose and hose clamps to secure more tightly to each of the fittings.
Location: Dallas, then Annapolis - now Laguna Beach CA. Well, not so fast - I'm back in Dallas. For good!
My issue was the bleeder was just old. Four years old. My fault for not recognizing it.
Easy solution for me is to simply replace - say every two years. At fifty bucks, it's worth it...
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Please let me know what you think of this suspension set up and results. I want to do the same for mine. Did you change the strut bars too?
Buena suerte!
I just got back home and heading out to San Francisco tomorrow (will be there all week). So not much work happening anyway.
Just keep looking, just keep looking, looking, looking, looking... (trying my best impression of Dori from the movie Finding Nemo)
Only changing the shocks and springs... no changes to the bars. This car will not see a track. I just wanted a better ride since the suspension felt tired and gone...
