A/C: R12
Since my R 12 a/c doesn't work anymore, I was told to rebuilt it before it could work again. BUT a guy I know have told me he has something called RS 24 which is mixable with R 12, and then it would not be necessary to rebuilt it. Does anyone have any experience with this? I don't know if this would be a good idea.
Issue has already been beaten to death, and there is no consensus. Do a search. www.epa.gov has a listing of approved "drop in" replacements and some pretty authoritative information on the subject. Freeze-12 seems to be the most poplular, but "drop-in" replacements for R-12 are mixes of refrigerants with molecules bigger and smaller than the R-12 molecule. They work as long as the system does not leak. If the system leaks even a little, the smaller molecules leak out faster, and the mix ratio gets off. Thermodynamic properties and compressor life suffer when the mix gets off.
Note that every 964 left the factory R-134a ready, even those charged with R-12. The service valves need to be changed, and if mineral-based refrigeration oil was charged into the system, it will need to be flushed out (not a big deal). If your system leaks, you need to fix it. If it does not leak, simply flush, install new oil, and charge with easily-available, inexpensive, and effective R-134a. There are nay-sayers, but every car maker in the world uses R-134a on non-EV cars and trucks. They are not all idiots.
I have been running mine with RS24 for two years now and it is still blowing cold. I have no clue if it is also damaging my compressor but the mobile air-con specialist who did it was confident it would be OK. He also rebuilds compressors so if it does fail I am sure I can strik a deal with him. I guess an annual service wouldn't be a bad idea though.
Four years ago, I drove my RSA across the desert in 110+ degree heat. Never moved the fan above 2. Now, it's a little weak. I'll convert to R-134, same as my ag equipment. These cars have an excellent AC, if properly maintained.
Shucks, these cars are perfect, if perfectly maintained.
Only because the service valves are different. I have forgotten the date the treaty was signed, but The R-12 production ban was effective on Jan 1, 1990. Through 1992 Porsche used up inventory of R-12, and started using R134a in 1993. Barrier hoses are OE on all 964s including the 1989 first year.
just flush and reservice with 134a if system passes the leak check...
what about hte reciever/dryer on my 1990 c2 i have a sightglass....... i thought you had to change it out?????
my r12 is still going strong
you can still buy small cans of r -12 on ebay.
