100k mile maintainence cost (parts only)
Info only: just tallied the 100k mile maintenance bill for parts. (Me doing wrench duty.) Included unanticipated (but not unusual) old rubber pieces that needed replacing.
Total: $800 ($us)
Per someone's suggestion a long time ago, I always write out my own garage work receipts for the car's receipt folder (for all my own work.)
Parts were sourced thru Witchhunter (injector refurb), private party resale (spark wires), and Pelican.
Qty. --- Item/Description --- Price/Unit --- Total
1 Valve cover gasket kit; 10.0906.093.m136 81.25 81.25
2 Ignition rotor; 930.602.902.02 26.25 52.50
2 Ignition cap;930.602.919.01 59.25 118.50
1 Fuel injector cable bracket;964.075.030.00 1.00 1.00
12 Spark plugs; FR-5-DTC Bosch, 999-170-183-90-M14 4.50 54.00
1 Spark plug wire set; Beru 225.00 225.00
3 Spark plug wire clip; 964.602.559.00 0.50 1.50
1 O2 Sensor; 965.606.126.01 116.00 116.00
1 Upper oil hose; 964.207.130.04 9.50 9.50
1 Lower oil hose; 964.207.217.00 12.75 12.75
1 Oil pressure sender fitting o-ring; 999.707.314.40 2.00 2.00
6 Fuel injector refurbishment & testing; Witchhunter Performance 18.00 108.00
1 Fuel filter; 928-110-253-06 18.00 18.00
2 Engine spark wire tie down nut; 999.591.592.40 0.50 1.00
1 Valve gap setting 0.00 0.00
1 Electric window switch repair; driver’s side passenger window control 0.00 0.00
1 Horn button repair & cleaning 0.00 0.00
2 Lower engine (capsule) tins’ spot rust removal & repaint; 0.00 0.00
Total: $800 ($us)
Nah... oil & filter was changed about a grand ago. (BPenn was still quite green!) Drained & stored it off to the side.
Many places are becoming *clean* and reassembled per spec for the first time in a looong time.
Next time in will be much more of a pleasure.
And, yeah, as always -- it does feel good.
$225
One of our canuk friends was making offers around here about 6 months ago for a group buy via a place near him that had garnered a fantastic price mistake.
Though I hadn't this in mind at the time, it seemed the deal of the decade. So we did bizness.
(And now I see they're going for $600+ ) Rennlist paid for itself, there, and many times since.
