shark fin re-attachment
anybody have a good way to re-attach the bolts to the shark fin assembly?
my mounting tabs have torn.
I have tried Gorilla glue and plastic cement, but neither have held long term.
I guess I need an abs specific glue/cement/epoxy.
suggestions please.
suggestions please.
Professor of Pending Projects
I used a two-part epoxy to fix mine... driver side. Still in place. I still need to replace it because of a piece of metal on the road that came flying and took it out...
Here is a photo after it was put back in place... but it looks in bad shape.
![](http://forums.rennlist.com/upload/dsc_00011_large_copy1.jpg)
Another vote on the 2 part epoxy and proper cleaning. I used a clamp to hold the bolt in place for 24 hrs before re-mounting to the car.
I used a 2-part panel bond adhesive, as used in body shops. Stop by a shop, and they might give you a tube with a dab left in it. After cleaning both areas, I put a dab on the clip, making sure to not have any excess - this stuff will not come off of anything. (if you get any of the adhesive where the fin might touch the body, you will not get it off later.) The wet adhesive clings very well, so I put the fin in place with the clip glued on still wet, held the fin in place with painters tape, but did not put the nut on. This way I knew the stud was in the right spot for the mounting hole. I let it set overnight, and then put on the nut. I also used this opportunity to install new rubber strips. At least the left side looks fantastic. Someday, the right side....
