964 Forum 1989-1994
Rebuild Options
Old Aug 1, 2008 | 06:03 PM
demonfish's Avatar
demonfish
but its tolerances and minute measurements and bearing clearances that worry me, if it was just heres and engine, heres a bag of parts, i'm sure i could do it. If I had some space.
Old Aug 1, 2008 | 07:20 PM
race911's Avatar
race911
One of the things Anderson and Woods both told me many, many, many moons ago was that everything for 911's pretty much "fits". Now that's not to say you don't measure everything, and double check the machine work. But any aluminum case I've ever pulled apart that went back together with a standard crank worked just fine with standard bearings. Of course everyone's anecdotal experience differs.........
Old Aug 1, 2008 | 07:41 PM
demonfish's Avatar
demonfish
270k km's on the car too :S... I think the best solution would be for me to strip it back to a short block, and have the bottom end and heads redone, then i'll fit manifolds and ancilliaries etc etc...
Old Aug 2, 2008 | 05:42 PM
pcar964's Avatar
pcar964
Originally Posted by springer3
I also leaks on the road, and washes into the waterways. Have some compassion for the fish, foul, and other creatures that live in and on the water.
what a ***.
Old Aug 3, 2008 | 01:10 AM
joey bagadonuts's Avatar
joey bagadonuts
Dude, that's uncalled for.
Old Aug 3, 2008 | 01:19 AM
Kahdmus's Avatar
Kahdmus
Originally Posted by pcar964
what a ***.
Springer was perhaps over reacting but just as likely making a joke. I think this is inappropriate either way.
Old Aug 3, 2008 | 01:26 AM
tbennett017's Avatar
tbennett017
what a ***.
That's even out of character for Kramer...
Actually I have been thinking more about the environment when I use solvents and all sorts of auto related chemicals... I wish my addiction wasn't so toxic.
Old Aug 3, 2008 | 02:08 PM
Dwane's Avatar
Dwane
Non-member with 4000 posts.....You figure it out!
later
Dwane
Old Aug 3, 2008 | 02:12 PM
Christer's Avatar
Christer
Originally Posted by Duck
If I do it myself, I can spread hopefully the smaller cost over a longer time frame.
I would recommend that anyone who owns an older performance car of any make, has some sort of slush fuund or starts to put away cash for some of the larger maintenance issues that *will* come in the future. In the UK, I would recommend that anyne who owns a 964 should put aside at least 200gbp per month starting as soon as or even before they acquire the car. In this way, one achieves your goal without pissing off the wife by having a 964 in pieces for a long period of time and all over the place when the time comes. Additionally, you do not have to have the car off the road for such a long period which means that by planning ahead you ensure a smaller break in your own pleasure time.
Old Aug 3, 2008 | 02:14 PM
Christer's Avatar
Christer
Originally Posted by demonfish
I have rebuilt engines before, but nothing of this scale, i'm talking 1.4 turbos, subb 200bhp... Not sure i'd have the required skill to work to the tighter tolerances.
I can take it out myself, and refit no problem, that will save a large wedge of cash.
I wont sell the car and buy a none leaky one, its taken 12 months of graft to get it this far, with around $15k spent...
It pulls 277 on minimal mods, so yes i could just reseal, but while its out, i may as well have it all refreshed... It is slightly tempting to do myself, but I just dont have the time, and the fear is starting, and not being able to finish, then forgetting where it all went.
The best case for starters is to strip down and take to someone who can warranty a rebuild.
I'll be taking a look this weekend to determine the problem... fingers crossed its something simple.
You should have boutgh my car in the first place, so at least then you would only have to spend money on getting it done pink all over the place
Putting aside money for maintenance on top of what you may spend on mods is damn useful....
Goood lucl!
Old Aug 3, 2008 | 02:16 PM
Christer's Avatar
Christer
what a ***.
I feel sorry for you...
Old Aug 3, 2008 | 03:54 PM
Uber 911's Avatar
Uber 911
Registered User
Demonfish, a thought is have Unit 11 in warrington do it. Danny really knows his stuff on engine builds.. every time I drop in he's always on 'another' rebuild. I dont think their prices are that bad.
chris
Old Aug 3, 2008 | 06:22 PM
demonfish's Avatar
demonfish
i'm still investigating....
i cleaned the underside and ran it till hot. Timing cover left side started to weep. as did rocker that side... but no drips - but i'm guessing when driving these will get blown about. It looks like the majority of the puddle comes from where the oil coats the back bumper and pri silencer, then it runs down when i stop.
Annoyingly though, i have oil smoke coming out of that sides heat exchanger, so its definately running down from somewhere. Inlet off i think, take a look from the top next...
Old Aug 4, 2008 | 02:01 AM
Oracle's Avatar
Oracle
later
Dwane
Hey,
That's really uncalled for!
I'm proudly building my posts as non-member and I hope that one glorious day I'll be like Kramer
Old Aug 4, 2008 | 09:54 AM
Colin 90 C2's Avatar
Colin 90 C2
if it's leaking from the top, you should look at the power steering seals and the oil sender. Both are common leaks and semi-easy to fix. both of these will leak down to the passenger side heat exchanger.
I also have the oil return line from the bottom of the sump now leaking and blowing back to the bumper.
All of these can be fixed without dropping the engine.
