Motor mount failed - Quick help needed!!!
I had the car jacked up doing some last minute checks before a track day tomorrow. When I got finished up, I put the jack under the engine and begun to raise the car. Suddenly a mystery fluid began to drip from my car. I freaked out and put the car back on jack stands. I traced the fluid back to the drivers side motor mount. I'm sure I need a new mount, but am I safe to do the track day tomorrow with the mount in this condition? I hate to waste a couple hundred bucks and the last track day till July...
What do you guys think?
Get a Case of PBR (your favorite) and all your worries will fade away.....
Okay, now for the serious stuff. I hope someone else can shed some light on this because I have never experienced such a thing?
Are these mounts "filled" or solid rubber?
I had mine leaking fluid and drive it for a few months (maybe close to half year) before I replace them with RS mounts. Not sure if I'm actually taking any risk but the car runs fine with leaking mounts. (my car is used for spirited drives on road only with low mileage, no track days and no daily transport)
Do you jack up the car using the engine? I know this was hammered to death in other threads, and most people thought it did no harm. I still have doubts, and I use the trailing arm to raise the rear one side at a time.
I had one of my mounts totally fail last year. The casing of the mount failed and tore through. This happened a few months after I purchased the car so I don't how long the fluid had leaked out before it failed completely.
Josh, call Sunset as soon as they open and see if Bob has one. If they do, we can figure out a way to get it to the track. I will have the jack and some tools. Text me if there are any special tools.
04 GT3, euro seats, tequipment bar, harnesses, Champion RG5's w/Hoosier R6's
Previous Mentionable Cars:
06 BMW M3 SMG - Tracked
01 911 Twin Turbo - Fast
02 Honda S2000, lots of fun!
77 930 Turbo – A real Handful
81 911SC – My first Porsche
68 Shelby GT500 – all Original
70 Mach-1 – Black Beauty
A great excuse to change both mounts to non-hydraulic. Either the factory RS or the WEVO will do. You will like them at the track.
http://www.wevo.com/Products/Chassis...gineMounts.htm
I can't compare going from hydraulic to RS, or Wevo since I have no experience.
Note that Wevo offer a soft and a hard compound rubber "pillow" insert for street or track.
The advantages are less engine motion = better shifting and better throttle steering at the track
