Scantool reset of low brake pad light?
I searched everywhere and could not find an answer to this. Sorry if this is an old subject.
I just got my Scantool working.
Reset the airbag light, (disconnect battery for the winter)
No issues with Motronic, (Pleasant surprise)
AC system had a bunch of codes that I just deleted because it works fine.
ABS section, could access, I have a C2, (is this normal?)
I did the brakes last year and broke one of the low wear sensor wires, so I left it off. The low pad iwarning lilght is still on in the dash lights, and I was under the impression I could reset /clear it with the scantool functions.
Am I mistaken in this assumption, and I really have to hook up another low brake light sensor in order to reset my warning light?
thanks!
Jon in GR
thanks!
Jon in GR
Burgled
you need to twist or solder the 2 ends together to complete the circuit on the sensor or the light will continue to come on as it still sees the fault.
Jon,
I think you meant you could NOT access ABS on your C2 with Scantool. That is normal as the Scantool only connects to the PDAS/ABS modules on C4.
Ricardo,
Sorry for my typo. Can NOT access ABS on the scantool, and I did not expect to either. my bad.
Nice Tool!!! Good job, and professionally packaged too! Only had one massive migrane headache getting it to work, but I'm strutting around like a banny rooster now!
Jim,
Thanks for the good advice on my brake pad warning lamp. Knowledge is a wonderful thing!
Thanks Guys!
Jon in GR
Jim,
Thanks Guys!
Jon in GR
Jon,
Is that your garage in the Avatar? Mind if I drive over for a visit and say, drop my engine, do some cleanup work, change a cam chain cover seal and then pop it back in?
What was the issue getting Scantool to work. Sometimes I get emails to help with troubleshooting so I'm curious as to your issues.
