GHL cat bypass pipe doesn't
Just installed a GHL cat bypass pipe...It does not want to seal properly to the muffler(small leak) Does anyone have any solutions?
thanks
Dwane
thanks
Dwane
you can replace the sealing ring and the clamp, but you may just want to get it up to running temperature.
If the leak is small, all the metal will expand and the leak should seal itself.
Dwane,
I would also carefully take a look at the bypass lip where it meets the seal ring. Make sure there are no bends or flat spots. If so, you can probably knock it back into shape.
