322x32mm Rotors - Q
any comment on these fitting my Cup - i have not contacted them but they "look" right from this spec
these look promising for a light weigh front rotor solution
Front Disc Diameter Height Thickness Min. Thickness Center Hole Bolt Holes
mm 322 72.2 32 30 103 5
inch 12.68 2.84 1.26 1.18 4.06 5
Part Number: DBA 52390BLKSL _____5000 Series
Part Type: 5000 series Fully Assembled 2-piece Black Hat slotted left-hand
Vehicle Fit: PORSCHE -> 911 (993) -> 911 3.6 Turbo 4, GT2 (02/1995 - 9/1997)
Part Details: This rotor features Thermal Stability Profiling for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. With a two piece design and an AlumaliteTM centre hat, the 5000 series is one of the finest rotors available..
search on 993 Turbo
thoughts?
search on 993 Turbo
thoughts?
How much?? I know Ilko ended up getting new brackets custom made by VCI to fit his 993 rotors he had gotten not too long ago.
As for myself, I ordered a set of 965 rotors from sunset at 151$ each. I know they'll start to track after my first outing but if you guys find a slotted disc, I might go with them for my next set.
Agent Orange
Hey Rob, here's my thread on the 993TT rotors: https://rennlist.com/forums/964-forum/415561-mmmm-brake-rotors.html
I ended up fitting them in, but it took 3 pages and new adapters to get it done
