964 Forum 1989-1994
cleaning motive power bleeder
Old 03-20-2008, 10:19 PM
Dwane
Dwane's Avatar
Default cleaning motive power bleeder
How do you guy's clean the unit?
Old 03-20-2008, 10:26 PM
deep_uv
RIP
deep_uv's Avatar
Pour a little denatured alcohol down the tube into the tank. Swirl it around. Wipe it out with paper shop towels using a long screwdriver or something similar.
Old 03-20-2008, 10:32 PM
Dwane
Dwane's Avatar
Thanks Steve!
Old 03-20-2008, 11:05 PM
LouZ
LouZ's Avatar
Location: Philly Area ----- George Washington took a dump in my backyard!
This is why I prefer the "dry" method...have yet to clean it out!
Old 03-20-2008, 11:35 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Can of brake cleaner?
Old 03-20-2008, 11:43 PM
deep_uv
RIP
deep_uv's Avatar
Yeah, I hate cleaning too, so I really had to think about it the first time. With the denatured alcohol, it takes maybe 2 minutes and it's clean as a whistle. I really didn't think it would be that easy. IMHO, you spend much more time than that refilling the reservior and re-pumping. Not to mention the air in the clutch circuit issue that occasionally happens. But, to each his own, either method is perectly acceptable. One thing for sure, it's always good to have multiple options!
Old 03-21-2008, 12:13 AM
kgorman
kgorman's Avatar
+1 for dry. I cleaned mine out last time by just wiping it down.
Old 03-21-2008, 07:24 AM
MisterRisky
MisterRisky's Avatar
when doing a full system flush I agree fully with deep_uv that it is worthwhile to go ahead and do it wet. If I do something small and just have to bleed the air from the front calipers I do it dry. When I do it wet I also use alcohol for the clean up.
Old 03-21-2008, 08:55 AM
LouZ
LouZ's Avatar
With the mods for quick connects, even the full system bleeds are easy.
Old 03-21-2008, 09:53 AM
Colin 90 C2
Colin 90 C2's Avatar
Lou, that's a great idea. Why didn't I think of that.
Old 03-21-2008, 10:14 AM
Chipster
Chipster's Avatar
Lou,
That's a slick set-up. I just had to replace my tube. I think I'll be making another trip to the hardware store...
Old 03-21-2008, 10:20 AM
MisterRisky
Lou, are those different caps for different cars?
Old 03-21-2008, 11:22 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Water cuts brake fluid -- just hose it out - in a safe place of course.
I, too, prefer the dry method.
Old 03-21-2008, 11:52 AM
LouZ
LouZ's Avatar
I got the universal cap also, it comes with U-bolts and chains for adapting to a wide variety of resevoirs.
The quick connects are "air hose"connectors. I like their function that I screw the cap on, then attach the bottle (as is now available from Motiv on their new style).
The good aspect is after the botttle is pressurized, I can disconnect the hose to top off the resevoir without loosing bottle pressure.
Old 03-21-2008, 12:03 PM
darth
darth's Avatar
Mine is homemade from a VW Jetta radiator overflow container with the quick disconnects. I usually let gravity do the work for me over a few days by hanging the device (i.e brake bleeder, oil funnel etc.) high up on a garage wall and direct the drain through the hose to the supply container of fluid used.
Bill
90C2
Quick Reply: cleaning motive power bleeder
