Speedlines light or heavy?
Bill - really nice.
Anthony - did you ever find new metal center caps for your polished Speedlines? I am refinishing a set of painted centers now and they are going to be polished for use on a set of Kinesis Super Cup wheels. It may be the only way now to get a nice set of metal. Cost be dammed. I know what I want and will not compromise.
I just noticed a new nuance the other day and hope one you two wth the new Speedlines can confirm. It looked like the yellow Speedline information tag on the inner hoop was lined up with the valve stem hole on the outer hoop when assembled. I had never noticed that before. Of course the valve stem is center between an opening in the spokes.
Jim
Jim
Yes the yellow tag is aligned with the valve stem. See picture.
BTW thanks for sharing. This is like Speedline **** thread. LOL
The really light weight wheels are either the early fuchs or the cast magnesium wheels. Don't forget Porsche is building a street car and to put light weight wheels on a car would mean more likelihood of damage and the original Fuchs were amazing in the forging process but I couldn't comprehend what it would cost to make single piece forged wheels to shape today.
Anthony, what I discovered was I had to remove the center crest to strip and polish the centers. It seems most people who try to remove these center caps used a screw driver so the edges have to be sanded to remove the imperfections. Hopefully yours are not all dinged up. A lot of work to be sure.
Jim
Jim
hi guys, considering saving weight is in my opinion a package, wheels tyres and spacers !?
I have done some home work and the lighter and cost effectif solution that I found ( but may not look period) is OZ magnesium 8x18 and 10x18 540€ each no spacer required or the lighter and to expensive is the Dymag mag/carbone 6kg/6,5kg very strong apparently made to your ET spec.
Konstantin
Konstantin
Many people don't like magnesium wheels for street duty. They corrode easily, don't age well etc. Nevertheless, you can find real magnesium Cup 1s (7.5 and 9 x 17) in Germany as per 964 RS, see ebay no 200179479138 and 200133519976 that are much lighter than standard and look "right". Dymags are on a different level altogether.
Hi AVoyvoda, I have seen these wheels for sale 4000,00€ +post it is an option, the Oz are new and 18"
for 2200 €+post (inc vat and garanty no cracks) I just both a set of original speedline mag on ebay for2300€ took a chance as their centres are all over powder coated and not drilled where the 5 nuts are going ( so never been used) the Dymag are fantastic I when in Jon Okley Gt3 aurround Brands hatch he has those wheels on the car so so smoth ( no affiliation) unbelievable!
konstantin C4
konstantin C4
I have both I use the 5 spokes w/cups on the trck and they feel very light.
Elliot
konstantin C4
konstantin C4
I would not recommend drilling out the studs on these for 2 reasons. One you would destroy their value and 2 if not coated properly afterwards could corrode and eventually crack.
Hi Anthony,those look like the 993 type,do you think it would be easy to convert to central looking??but they look a bit od with the grooves for the nuts (so frustrating I can't send you the pictures) also they would need to be ovbiously be powerder coated in the drilling area ,one think they powder coated the surface that aply to the hub wich I am happy as it protected the mag for the time beeing but I want to have clean up, some have said to leave it but I am worried that it would not seat perfectly trought if the powder coating is left.
KonstantinC4
KonstantinC4
KonstantinC4
KonstantinC4
The wheel itself is centered by the hub so seating properly shouldn't be an issue assuming you are accurate with your drilling, machining recommended. I would apply some type of coating being magnesium alloy to prevent any corrosion issues. Exposed magnesium will corrode badly especially if it gets around salty and humid conditions.
