Sprocket holding tool 9191
The tool is used to hold the camshaft sprocket whilst the centre bolt is undone.
I am trying to stop the dribble of oil from the rear of the sprocket housing, where the camshaft passes through into the cam carrier.
There is an "O" ring and a small gasket behind the camshaft sprocket, replacing these will, I hope, cure the leak.
Regards
Les
