mye new toe-heel pedal!
http://hargettprecision.com/index.ph...als/rxgpa.html
Ok cool - a few years back they stopped making them. I guess they were just out maybe...
That pedal is not plug and play for a 964...just an fyi. You need to turn the base plate around and fiddle with it a bit to make work for our car...but it's fantastic.
For the rennline adjustable- i usually install those with only the bottom wing in place. And i remove all the rubber bits as you want a sticky clutch and brake pedal surface (oem rubber pad) and a slippery gas pedal surface in our cars.
Cool. Great info guys. I’m going to try adjusting these tomorrow and if i can’t get where i like under heavy braking I’ll get one of these adjustable pedals.
Bumping an old thread for the second time...
I haven't seen much talk about the Rennline adjustable lifter plate combined with the Rennline pedal cover. Seems like the easiest solution as there's no need to remove the existing gas pedal.
Any thoughts on this direction? If so, how much did you raise the gas pedal?
http://www.rennline.com/Rennline-Adj...ductinfo/PA70/
I also found these from Schnell Performance-only $99 for all 4 pedals:
https://schnellperformance.com/produ...-insert-manual
