Exhaust rattle?
7th Gear
Exhaust rattle?
I would describe it as a dry rattle - sounds like it's near the rear exterior (like exhaust). Frequency/tone varies with RPMs. Loose exhaust shield common? Thoughts?
If anyone is willing to listen to the noise over the telephone, I'm willing to pay a little by the minute via www.rogomo.com (disclosure: I work for rogomo .
Agent Orange
Have you checked all bolts for loose connections? I would start with that first. If you don't find anything, then remove the rear bumper (very simple) and check the heat shield above the primary muffler.
http://www.northerntool.com/webapp/w...&ci_sku=160875
Northern Industrial Mechanics Stethoscope
Helps detect noises in engines.
Sale $3.59
Your rattle could be internal to the cat , 1st muffler , 2nd muffler , heat shields etc etc etc
Sale $3.59
My guess would be the shields (two piece) around the cat. There are a number of little bolts that come undone. Also, they can catch and retain debris, pebbles, etc.
I found one of mine loose today (just as Joey B. describes above). I had mine on a lift today, which made it relatively easy to spot. Not sure if I would have seen it using the jack stands. Good luck.
