Bucket seat/sport seats 964 vs 944
Dear All,
Does anyone know if the sportseats from a 944 fits a 964? I know it does from 928 to 964 but from a 944.. I have found nice sport seats I thinking og buying...
Location: Dallas, then Annapolis - now Laguna Beach CA. Well, not so fast - I'm back in Dallas. For good!
1 Post
The Sport Seats for the 944 series (not 968) is the same as those used on early 80's 911s thru 964. They changed the seat (and mounting) on the 993.
FWIW, I think the change was a major setback. The newer Sport Seats do not fit me at all. The previous version (like I have on my 951 and 964) are just superb.
Greetings - Reviving this thread rather than starting a new one since I'm going to mount some early (thru '85) manual sport seats in my 964.
Who has mounted the early manual sport seats (the ones through 1985) into a 964, and if you have, how did you resolve the lack of a seatbelt receiver mounting tab? Also, since these manuals sit lower, did anyone find a solution to give back some height adjustment?
Any help is appreciated!
The seats I'm installing aren't the sport seats from the 964 or later 944, they're the manual sport seats from the earlier 911's and 944's (pre-1986).
They'll mount right up (hole location is the same) but the height is like 2 inches shorter than the power seats, and they lack the ear for the seatbelt receiver.
There is a specific seat belt bolt receiver from the 964 RS that is available from the dealer. It welds on the center tunnel from underneath.
Otherwise you can make your own with thick steel stock and the correct tap, and weld it to the tunnel.
There is also the possibility of mounting a receiving tab from another car to the seat mounting bolts, althogh I am not a fan of this methd.
On a tangent, have you made sure that the backrest adjusting wheel on the early manual sport seat will not foul the shell/carpet as the seat goes back? I have had that issue with a Recaro A8.
Hi George,
Yes - the OEM sport seats only have the wheel on the outside so it won't be an issue. Thanks for the info on the options for the seatbelt. I'd like to avoid any permanent mods for this since I may reverse it someday so I've considered using a set of the Wedge Engineering mounting plates which include the ear for the seatbelt receiver as part of the plate.
Thanks for the input!
I used the Brey Krause receiver mounting tabs on the inboard side of my pole positions. Would that work for you?
