993 calipers
Hi guys,
I know we talked about it a dozen of times but I just wanted to be sure before I jump on and buy something that is wrong.I found a pair of calipers there are from a 993 with reference 993 351 42 100 /200 pistons are 44/36 (colour black) ,would they fit on 322x32 discs for a brake upgrade.
many thanks Konstantin
The 322 disc you are quoting sounds like what I have on the front of my car which has (effectively) RS brakes. If you are talking about the front of your car then you should use IMHO the 964 Turbo caliper with that disc on the front.....its a long time ago now that I upgraded my brakes so you may want to wait fro a guru to come along just in case....
You have two choices for front brake rotors, the 91/92/964RS front rotor which is 322x32 and accepts the pad for that caliper known as the "S4 caliper". The other is from a 94 3.6 Turbo, also 322x32, but has a smaller hub and accepts the pad from the "big red" caliper.
Hi guys,
w/ any of the above calipers you will also want to use n/a 993 rear calipers and a 23.8mm m/c
...322x32 rotors but it's a waste of rotor.
At high speeds on the track, it is impossible to lockup the brakes on initial application which shows that the brake system can be improved. This is the main advantage of running say the 380mm endurance brakes on the race cars. On the street, no, there isn't a stock Porsche brake system that needs to be upgraded for performance reasons.
Brembo has a really nice 304x32 that w/ the right hat is perfect for the smaller 993 caliper.
this rotor
![](http://forums.pelicanparts.com/uploads11/Brembo+304x32+XA3+33+10+111189733358.jpg)
w/ an approprite hat
![](http://forums.pelicanparts.com/uploads12/930+hat+and+bobbins1198189832.jpg)
and caliper adaptor would have plenty of torque, thermal capacity and be lighter to boot.
hi,
thanks Bill,thanks Geoffrey for your reply ,(sorry I was away for a few days).
So if I understand well the 993 caliper is ok for 322x32 rotor witch is 965 rotor, but the pad is smaler than the big red/ black (993 pad 132x48? big red 132x58?) so that Brembo rotor is the perfect fit, that is interesting,in your opinion what combo would make better brakes big red/ black with 322x32 or standar calipers ( 132x48 pads pistons 40/36) with 355x28 sloted discs with alloy hud from Brembo
Konstantin
Konstantin
front 322x32 w/ Big Red(or black) 36/40 caliper(132x58 pad) rear 299x24 w/ 993(rear) 30/34 caliper(98x44 pad) 23.8mm or 25.4mm m/c
front 322x32 w/ 993(front) or 964RS or 965 3.3 36/40 caliper(132x48 pad) rear 299x24 w/ 993(rear) 30/34 caliper(98x44 pad) 23.8mm or 25.4mm m/c
all calipers have a limited range of rotor diameters. 322 to 330 is the limit for these calipers. 355 is way too big for the application
