964 Forum 1989-1994
Engine removal issues
Old Dec 13, 2007 | 01:22 PM
Naptown's Avatar
Naptown
shell
File Type: jpg
Old Dec 13, 2007 | 01:44 PM
hans57's Avatar
hans57
Hey, is that an Yellow FJ in the background?
Old Dec 13, 2007 | 01:52 PM
Naptown's Avatar
Naptown
yes it is. i'm a toyota freak. puttin dana 60's under it.
Old Dec 13, 2007 | 02:08 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
I had leaks around my thermostat too. One of the houses was seeping through the rubber itself. I replaced all of them for good measure. Before ordering your hoses, look at the part number of the thermostat. There are two models and they use different hoses. Ask me how I know.
Old Dec 13, 2007 | 02:25 PM
Naptown's Avatar
Naptown
Will do.
Old Dec 13, 2007 | 02:26 PM
Naptown's Avatar
Naptown
Anyone know what it should cost to resurface my fly wheel? Place quoted me 95.00. There aren't any groves on the flyhwheel, but it does look a little burnt blueish.
Old Dec 13, 2007 | 11:43 PM
Fred's 964's Avatar
Fred's 964
Naptown, I'm currently removing my engine tin to clean and repaint. You might as well while the engine is out. Then you can detail the entire engine. Engines can be beautiful too!
Old Dec 14, 2007 | 09:06 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Originally Posted by Naptown
Also, the pan that the engine sits in looked a bit rusty. I was thinking about removing it and taking it to get sandblasted and powdercoated. Do people do this?
My engine tin was rusty so I had it powerdercoated. It turned out great and was less expensive than I expected. The cost was $120 ($20 per piece). I splurged and had the engine fan painted too.
Old Dec 15, 2007 | 12:16 AM
DWS964's Avatar
DWS964
Unhappy
These are the reasons I am reluctant to drop my engine to put in a new clutch. I know that once I get it on the ground, I will never finish the job because there will be just one more "might as well" thing to do. powder coat this, put in a new sensor, clean that, new gasket here/there, ... And I will blame it all on Rennlist.
Old Dec 15, 2007 | 12:24 AM
Indycam's Avatar
Indycam
But then again , you will not have it to drive , so there is your motivation .
Old Dec 18, 2007 | 02:49 PM
Fred's 964's Avatar
Fred's 964
Without the 993, I know I would be itching to get the 964 back together quicker than it is taking to do all this extra "while I'm in there" stuff. The weather has started to get cool, so I miss the Cab. Better get it finished quickly...
