964 Forum 1989-1994
transmission flush DIY
Old Nov 28, 2007 | 07:31 PM
kgorman's Avatar
kgorman
Default transmission flush DIY
I searched around here, pelican and johns 964 site, but I can't find a DIY for transmission fluid flush. Anyone do it before?
Old Nov 28, 2007 | 07:38 PM
Tom W's Avatar
Tom W
p-car.com has one. I've done it and it's not hard at all.
Old Nov 28, 2007 | 08:48 PM
kgorman's Avatar
kgorman
Found it, thx Tom. I just ordered some Swepco 201 from Pelican as well.
http://p-car.com/diy/transmissionfluid/
Old Nov 28, 2007 | 10:28 PM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
First. Make sure you can remove the fill plug... don't ask me why...
Old Nov 28, 2007 | 11:15 PM
Chris M.'s Avatar
Chris M.
Swepco is the gold standard for the 915 but I thought Mobil 1 was best for the G50/G64.
Also, I didn't use that tube filling method. I bought an $8 pump that you can pour the tranny fluid into and then pump it in half a quart at a time. It was very easy, assuming you can get those plugs off!
Old Nov 29, 2007 | 01:04 AM
kgorman's Avatar
kgorman
Rob @ SCarGO filled with Swepco last time I was in, and it's been fine for me, so I am sticking with it.
Old Nov 29, 2007 | 04:16 AM
donoman's Avatar
donoman
Is this 75W90 the standard for 964's? My buddy (a Porsche mechanic) told me to use Swepco as well.
Old Nov 29, 2007 | 12:10 PM
C4Russ's Avatar
C4Russ
I used 75W90 recently. I filled the case from quart bottles and a $8 bottle top pump from Shucks. Worked great and pushed in the right amount of oil as it's easy to try to push too much into the case at once. It's not like it's open case, the oil has to flow around the gears and settle into place.
Be ready to see some dirty oil come out of there. I was shocked to see out black it was. I have no idea if it's the orginal oil or not but the difference in shifting once i was done was amazing. Mobil 1 for me.
Old Dec 3, 2007 | 09:52 PM
jgrosjean's Avatar
jgrosjean
I filled mine with a long tube and funnel attached to the left rear fender. The book said it held 4 quarts, so I poured in 4 quarts. The garage floor was quite a mess.
Old Dec 3, 2007 | 11:00 PM
kgorman's Avatar
kgorman
Done! Thanks guys it was easy.
