Does your engine undertray....
I'm in the process of fitting an undertray to my Race car (seriously) and I run one on my street car. It does not touch the silencer if we are talking about the secondary muffler. There is enough movement in the mounting of the secondary muffler to move it slightly.
I keep mine on the race car, and my street car... there are specific rules in racing that keep earlier 911's from having underbody paneling to improve aerodynamics... but the 964 came with it so why not keep the advantage. Ever see the underside of a 959?
*I didn't mention primary or secondary as I've heard some refer to it as a primary on the basis that the cat is not a muffler.
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
so i take it that the general consensus is to whip off all that undertray? i thought it was meant to add stability at high speed..for the aerodynamic flow?...or is that all-sales talk?
The only plus point i can see with it, is that it keeps everything clean under there.
Do you remove all the panels or just the rear one under the engine?
As far as aerodynamics... my 996TT can go up to 190mph... no engine undertray in that car...
Anyway... no tray here, nor secondary muffler... better access to the plugs when maintenance time comes around...
