Check engine code
Check engine code
I am still dealing with my cold idle and stall problem. I pulled a 1222 code out today.
What do you think I should do to handle it?
Technical Guru
That would explain your idle problem. Have you recently removed the DME control unit from under the seat to install a chip? Or played with any of the wiring? You seem to have a lot of "loose contact" faults? The first thing to do is to stick a voltmeter on the wiring harness connector for the ISV, turn the ignition on and check for battery voltage. What did you end up doing with the O2 sensor "loose contact" problem?
1X22 - Idle Speed Control Activation (x=2 intermittent)
Can you check your idle speed switch with a hammer or pc software?
Are the connections to the switch and the ISV solid and clean?
I simply checked and replugged the 02.
As for the DME I have made no changes.
I did add a cat bypass. Is it possible this is creating an issue.
I ALWAYS GET FREAKED OUT ABOUT ELECTRICAL PROBLEMS.
