ERP rear monoballs & spring plates?
Elliot, what's wrong? The monoball cartridge fits in only one way and the spring plates can go either way, but you need to determine how much camber you require. If you can't get enough camber, or have too much camber, turn the plate 180 degrees.
Hi Goeffrey,
I got these from smart racing
1 I'm not clear on how the spring plate connects to the monoball.
2 I'm not sur if tis is the right diagram for the Monoball?
3 What wouldn't you use the max camber setting on the spring plate orientation?
Help
Elliot
Help
Elliot
