HELP...car wont start and backfires LOUD
I am puzzled. I have had some recent issues with my car.
I do have a cat bypass and straight pipe. I replaced the DME and put the new one back in. No change. I did have the ISV off but it looked clean.
Before it would run ruff and bog with a bad idle. Now it just wont start and backfires loud. I dont even want to try starting it again.
I feel its somewhere in the ignition or DME.
This is freaking me out. Please offer up some places to start looking.
Anyway....I used the pedal method to the code and I am getting 1224 so it must be the 02 censor. It must be bad. I suppose I should really look the wiring harness over again.
Anything else you can think of that related to this code?
A bad O2 sensor shouldn't prevent the car from starting.
Since you had the ISV off, maybe ensure it's properly re-installed?
TR6 should be able to help you out a bit with ISV questions, He's an "Expert". Be leery of anything he tells you to do with a screwdriver, though.
