Cooling Rear Brakes
Agent Orange
This comes in the heals of me completely obliterating my rear brake pads at the track last weekend. My thinking is that if I keep my rear brakes cooler I can get less fade and my pads will last longer.
In the front, with larger pistons and higher pressure, my pads have 30% more surface left than in the rear. I've installed the RS brake cooling ducts in the front, which along with the stock air scoops provide excellent cooling. Can I achieve something similar in the rear?
Now I know the engine is in the rear and there is a lot more heat generated, but if there is any way to get some fresh air in there and someone has successfully done it I'm all ears. I thought of installing some ducts similar to the front and channel them around the trailing arms, but I'm afraid that would interfere with ground clearance.
Anyone been there, done that, and lived to tell about it?
What kind of rotor temps are you experiencing? It really isn't typical for the rears to get overheated, especially if the stock pressure limiting valves are still installed.
Agent Orange
Unfortunately I don't know the exact temps. Where are the limiting valves located, so I can check if they're still present? I am also running cross-drilled, vented rotors in the rear which doesn't seem to be helping my case much. Everything else is stock.
The pressure limiting valves are located on the output of the ABS pump, under the black cover in the front trunk. Your car should have only one on the rear circuit since you have 3 channel ABS with 1 brake line feeding both rear brake calipers.
Yep, that ain't right. Were the rears locking up on the track? I agree with the others that it is either a proportioning valve problem or pad issue but I run rears almost all year compared to 2 sets of front pads on my race car.
Agent Orange
It's not a sticking piston, unless both rear brakes have sticking pistons, which is unlikely. Both rear pads wear out much faster than the fronts...
I don't experience any lock up in the rear at all at the track. I'll check the valves over the weekend and will let you guys know.
another possibility is oem rubber lines. Their usual failure mode is internal swelling. This allows the brakes to be applied but retains line pressure after release.
