Cabrio Roof Leaking when Stationary
I get a steady drip on the driver side from above the edge of the quarterlight frame on the door when standing or crawling in heavy rain. When driving normally there is no leak. The passenger side is OK. The seals appear to be the same and in good shape. There are no other leaks even in torrential rain on the motorway. It appears that water is running off the hood and somehow not being channelled away in the gutter at the edge of the hood. Any ideas as to how to cure this very welcome!
IHI KING!
Ian,
I had a similar problem. Mine was caused by worn or tired weather seals around the door/roof.
See https://rennlist.com/forums/showthre...highlight=seal
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Ian,
Same here... resolved by replacing the weather seals...
OK, it looks like Pelican is no longer selling these seals. Where else can I buy them?
The other night, I had my cab out for the first time ever in the rain. The driver's side leaked constantly from the top of the triangle glass. When I made a left turn, the water gushed into my lap. As long as I was going straight or turned right, the water only ran down the inner window. BTW, it must have been a funny sight as I'm pumping gas with my lap fully soaked.
IHI KING!
If Pelican isn't selling the seals, try another source of factory parts. My favorite is Engine Builders Supply www.ebsracing.com (no affiliation).
I would think Forestfine (http://www.forestfine.com/) have got to be a good bet in the UK. They seem to do a huge range of Porsche seals etc.
Dave
Dave
