Oxygen lanbda sensor CEL
After putting everything back together from my adventure of a valve adjustment I am getting an O2 sensor CEL warning (confirmed with Doug's software).
I've checked the following:
connected in engine bay
resistance across heater wires is ~8 ohms (two white wires)
sensor housing is grounded
when warm sensor produces voltage of 0.09 to 0.5 (black wire), and
Scantool shows O2 sensor reading of 89-90 at idle.
Is there something I missed? It was working fine before the valve adjustment and it seems that it should be working properly still. One thing I might add is that I sprayed it with PBBlaster to get it out and I applied antiseize when re-installing. Could either of those affect it?
Frank ,
The votage range from the O2 is showing a problem . Roughly the O2 should be switching between 0v and 0.8v .
The DME creates a fixed 0.45v "O2" signal if the O2 sensor has given up completely.
I would disconnect the O2 and take it back out and take a look .The O2 is not full of cleaning fluid ?
It may be that a new O2 is the fix . Ah well , could be worse !!
Geoff
KS400200,the oldest 964 on Rennlist,unless you know differently !
Geoff
Technical Guru
Frankvan, I just ordered one so I'll save you some time in case you find you need to order one. The best price I could find was Sunset at $140. The worst was my local dealer at $210. Part number is 965-606-126-01.
The local parts place catalog shows two Bosch sensors applicable - one for $130 and one for $90.
The $90 looks like it might be the Bosch universal 3 wire sensor.
Further to this, has anyone used a Bosch universal 4-wire sensor? The only difference I can see is that the 4th wire provides a dedicated ground signal rather than relying on the housing to ground through the exhaust. He has the 4-wire Bosch universal for $60 and says if it is compatible it might give the ECU a "cleaner" signal. (He has fitted the 4-wire type to other 3-wire type vehicles that had signal problems and had good results)
