Cat part number from 964RS
Technical Guru
That is PAG's equivalent of a cat bypass, option M150. The standard MY92 RS catalytic converter (same as the regular models) was part number #964-113-213-16.
Technical Guru
Dr.Ing. h.c. F.Porsche AG ("PAG")
It is a regular option available in countries where leaded fuel is sold and it is still available on the latest models. If you look at the wiring harness connector at the DME control unit you should also see a little white jumper with the part number #964-607-422-00. That tells the ECU to function without the O2 sensor.
![](https://members.rennlist.com/jandreas/DME-CountryCode-Jumper.jpg)
