964 Forum 1989-1994
need torque spec for valve cover stud bolt
Old 09-07-2007 | 03:48 PM
boze_man's Avatar
boze_man
Default need torque spec for valve cover stud bolt
part looks to be 999-062-009-02 stud BM 8x28
thanks
bill
Old 09-07-2007 | 04:06 PM
deep_uv's Avatar
deep_uv
RIP
thanks
bill
7 ft-lbs.
Steve
Old 09-07-2007 | 04:41 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
The studs for the valve covers that sit in the camshaft housing, Porsche part no #999-062-127-02 (M6 x 25) do not have a torque spec. There is a height spec but I'm not sure what it is. If nobody else posts it, just get the height close to any of the other 33 studs and be careful not to over-tighten because they snap real easy.
Old 09-07-2007 | 05:16 PM
boze_man's Avatar
boze_man
i thought the nuts were 7 ft lbs...but stud is same?
Old 09-07-2007 | 05:35 PM
JasonAndreas
Technical Guru
As Steve wrote, the nuts should be torqued to 7 ft-lbs but there is no torque specification for the studs.
Old 09-07-2007 | 10:41 PM
boze_man's Avatar
boze_man
thanks jason for the right part number....
i found out the hard way i had the wrong part number...upon driving 45 mins to pick them up and after a casual inspection realized i had wrong part...UGH...i could see that 8x28 was too thick...doh...
jason, for whatever reason your post was not visible at time i asked the later question bout the nuts vs stud torque amt...maybe i didnt refresh the web page?? if i had refreshed i would have saved some time and aggravation...
jason thanks again for your help and correct info...
now just need to figure where to get one? i was hoping to button this up over the weekend
Old 09-07-2007 | 10:55 PM
darth's Avatar
darth
The studs have a metric thread (i.e. probably M6 x 25 as Jason mentions, 8-28 is a British thread) as all the bolts on the engine are metric. The studs are screwed in until the unthreaded section meets the surface or until they're at a height which allows the nut to catch all the theads when the cover is in place. It looks prettier if all the studs are at the same height. To lock the stud into the cam housing use some red or blue locktite.
Hope this helps
Bill
90C2
Old 09-08-2007 | 01:10 AM
boze_man's Avatar
boze_man
Hope this helps
Bill
90C2
thanks bill for advice...not to worried bout pretty...will try to salvage existing stud and use till can get replacement...was hopin to button this thing up by end of weekend...
