964 Forum 1989-1994
Too much oil - How to limit the damage?
Old 08-14-2007, 04:23 PM
  #31
DarrylH
DarrylH's Avatar
Some people here have roughed up the dipstick in the critical area to make it easier to read. I just ignore the stick, since I know my gauge is accurate. Heresy, I know, but it works for me.
Old 08-14-2007, 06:08 PM
  #32
polar964
polar964's Avatar
That's right Darryl, the dip stick has been marked, but as Greg had pointed out with his oil and mine is the same, it is that clean (like the colour straight from the can) its hard to see. Not that i'm complaining clean oil means clean engine
Paul
93 C2 Polar Silver
Old 08-14-2007, 06:56 PM
  #33
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by TR6
Pour the cat litter (the cheaper, the better. Nothing fancy) all over the oil (enough to completely cover the surface of the oil spill).
and if you buy cat litter that comes in a 5 gallon plastic container you can drain the oil directly from your engine & tank into the container on your next oil change and never have to worry again about overflowing your oil pan.
Old 08-15-2007, 09:55 AM
  #34
Vlocity
Vlocity's Avatar
The easiet way to read the dipstick is to lay it on a paper towel and look at the corresponding "wet" location.
Regards,
Ken
Old 08-15-2007, 10:03 AM
  #35
cobracarrera
cobracarrera's Avatar
Regards,
Ken
Smart Idea....You see, I can always learn something new on Rennlist.
Goes along with the famous old joke I guess. How do you find the wet spot on a fat girl?
Roll her in flour......... J/K
Old 08-15-2007, 11:35 AM
  #36
Superunknown
Superunknown's Avatar
Yep, one side of the dip stick (the top side) seems to have the right indication of the level of oil whereas the other side (underneath) seems to have oil all the way up the stick. I just go off the gauge now and make sure it tallies with the mark on the top side of the stick!
Old 08-15-2007, 05:00 PM
  #37
polar964
polar964's Avatar
Yep, that's what i found. The level/mark on the top side of the dip stick would appear to correspond with the gauge. I never try to get the level bang on as that is one sure way to over fill. Keep it just between half and three quarters on the stick and an eye on the gauge and that will do nicely. Just under and not a bit over
Paul
93 C2 Coupe Polar Silver
Drive your Passion ... Drive a Porsche .. better still drive a 964
Quick Reply: Too much oil - How to limit the damage?
