Recaro seat mounts (split from the Random 964 Picture Thread)
Great looking car schlicht911.
6 points? What are you going to do on the driver's side? I just got my seats and harnesses installed but still need to do the eye bolts at some point.
Originally Posted by Marc Shaw
I got the sub-belt harness bolts in on the passenger side today.
Marc
Marc
Super Duper Moderator
Originally Posted by Chris M.
6 points?
Drill the hole just big enough for the bolt and mount it with a huge reinforcing plate underneath. I tried using the 996 B-K sub bars but the angle was totally wrong so I had to drill the holes.
Marc
Yes, Schroth hybrids.
Same thing - I already got them installed and it only took a little DME relocation.
Marc
Marc
Originally Posted by cobalt
I was wondering why you didn't use the 996 sub bar?
The only place to mount the B-K 996 bar was either at the front seat mount holes (way too far forwards) or at the rear seat mount holes (too far back). There is nothing to mount the bar to at the ideal location and, being handier with a Dremel than a welder, this seemed to work.
The only other option would have been to sandwich the sub-bar between the sliders and the side brackets but that would have required some extensive sub-bar mods to make it fit and then the sub-straps would be relying on the same mount bolts as the seat -- I'd rather spread the load out between different bolts. Safety is not a compromise.
If you have pictures of a successful mount that puts things in the right place, I'd love to see them as I could not make it work.
Marc
Schroth specify that the sub belt must run 20 degrees backwards, no more and no less.
Marc
Marc
What seats are you using? The GT3 seats are set up for a perfect 20 degree angle with the sub bar, so it worked perfectly for me.
Marc
Marc
Originally Posted by CWay27
Well Mark, that's how they are actually mounted. Not in sandwich but on top of seat side bracket. When mounted the bar aligns with sub hole in the seat. see picture below to show where the bar mounts.
The seat opening is actually slightly forward of were the bar is located making it a perfect set up.
Marc
Marc
Marc
Marc
Basic Site Sponsor
Basic Site Sponsor
Hmmm. You guys are running the 996 sliders in your 964s. What else do you have to do besides bend the front tab back up into the rails?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
The only difference I can see is that those do not look like the Recaro side mounts that I have and those do not look like the Recaro sliders that I have so I'm not sure that the way you have it set up would have worked for me. What type of side mounts and sliders are they?
I'll have to have another look at it tonight.
Marc
Interesting - thanks for the photo.
Marc
Marc
See picture below. the rear holes are slotted to adjust rake (front to rear) but the bottom holes (for sliders) are staight and not slotted.
I used the BK side mounts and 996 sliders. Just bend the tab up and you are set to go. I needed the BK side mounts to lower the seat and angle it back but I am assuming the Recaro side mounts will do the same.
Cway: I am confused - the picture of the 996 GT3 side mounts do not look like the side mounts in your other picture?
Marc
