Anyone installed OMP seats?
Thanks Marc. The problem, and I don't think it matters what brand the seat is, is finding the bracket that allows you to retain use of the stock seat belts along with the harnesses. It's tight on the transmission side so a cleverly designed bracket in there would do the trick. I'm searching around for the Recaro one right now. Did you see that 993 at the track?
I am using the second one pictured to attach the harness to the inboard mount and the third one to retain use of the stock seatbelts for road use.
Marc
Marc
Originally Posted by Marc Shaw
I am using the second one pictred to attach the harness to the inboard mount and the third one to retain use of the stock seatbelts for road use.
Marc
Marc
No, sorry. I got that wrong.
I meant that the second was used for the OUTBOARD harness mount (to the stock seatbelt mount site) and the third one to retain the inboard seat belt. The inboard harness is attached to #3 using the shorter version of #1 -- make sense?
Marc
Marc
