C4 will not Idle
C4 will not Idle
Sorry Guy's, seems I need you help again, during and after a longish run at "warp" speed, the engine will not idle, it simply cuts out. Makes life a bit difficult at roundabouts and traffic lights.
Occassional, during acceleration, she hesitates, but picks up OK. It would appear that prior to my buying the car, it has had a brand new Idle speed control valve fitted, is this relevant to my problem?
Any ideas, Any solutions ??
Cheers
Charlie
Cheers
Charlie
a similar question a week or so ago concerning no idle. check to see if the idle control microswitch is being activated when the throttle is released. if you do a search on this someone has posted pictures of this. also covered in adrians manual. the release of the throttle causes a little flange on the throttle control to depress the microswitch which is responsible for maintaining proper idle speed. had a similar problem 4 months ago, and a simple throttle cable adjustment solved it. good luck-----------tom
