Teardrop mirror question??
I've got teardrops on my rhd C2, which were on it when I got it.
I've noticed that I've got a bit of a blind spot on the drivers side occasionally and after a scare, religiously double check now. Sometime you don't realise there is a blind spot until a near miss![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
While in slow traffic the other day I realised that it looks like the passenger side mirror has a wide angle of view compared to the drivers. Anyone else noticed this and could I get a similar mirror for the drivers side that would probably eliminate the problem.
ta.
ta.
Here is a link to convex mirrors for both sides, however if you put it on the drivers side objects may appear smaller than they actually are.
http://www.carmirror.com/results/ind...er=6&liter=3.6
Super Duper Moderator
Proper adjusted, there should be very little blind spot, even with a 964.
The first thing that is taught at a DE is correct seating position, mirror postion, and hand position -- it is not all as obvious as it sounds.
Marc
Marc
Amen on the mirror adjustment procedure. I do mine as recommended, and I drive on the Atlanta downtown connector each day to work. I confirm proper adjustment by watching a car I just passed. As soon as proper adjustment is confirmed, I change lanes without looking over the shoulder. No problems, and I have been doing it that way for years.
Marc
Marc
This may help also.........Check it out it's about 3/4 down ..........
http://www.racerpartswholesale.com/mirror.htm
Longacre Racing Mirror Kits
14" Mirrors
Now Only $56.95
14" Mirrors
Now Only $56.95
