Yet another Antenna Booster replacement (Dash removal post)
The wire is so thin it's very hard to do. I tried putting a new coaxial plug onto the end of it but had no luck getting a good connection. Other then the cost of a new booster replacing it is not that big a deal removing the dashboard.
Check the end of the suspension madness thread. We just changed my antenna booster yesterday. Pulled the dash cap and changed it relatively easily (for Goughary, 964 ninja).
I am trying to locate where the connection between my WS and the cable is ? I had my windshield taken out and replaced and since then radio reception is poor, I guess something might not have be reconnected ? Should I remove the dash to find out ?
Antenna connection
On the 964 the antenna booster is on the right side under the dashboard. The antenna connector is also on the right. Removing the dash top is relatively easy to allow access.
Thank you for that. I will remove the Dashboard and will probably find the solution. I am almost sure they did not reconnect the antenna when they removed the windshield !
Right when I was starting to remove the dash I noticed a loose wire coming out of the dash on the passenger's side right next to the windshield. See attached pictures. Maybe this is the reason for my very bad reception ? Where does this wire connect to ? Obviously it has not been reconnected when they put the WS back in ? Does anyone know Please ?...
Any help greatly appreciated ! Thanks in advance.
Right when I was starting to remove the dash I noticed a loose wire coming out of the dash on the passenger's side right next to the windshield. See attached pictures. Maybe this is the reason for my very bad reception ? Where does this wire connect to ? Obviously it has not been reconnected when they put the WS back in ? Does anyone know ?
You are looking at the antenna connection to the windshield... The original Porsche windshield has an antenna wire embedded and the wire connects to a wire into the antenna booster - that's why you have the booster. If that cable is not attached, you essentially do not have an antenna
Thank you for confirming this. It is the proof it was torn out when the windshield was removed... Now that this can not be reconnected anymore, what would it be posible to do ? I am not sure if under dashboard for antenna not too visible do exist ? If anyone has a viable solution that would be great !
Thank you. I still have the original windshiels with the antenna in there but it can not be connected normally because the connector and wire have been torn. I just bought a small antenna booster but it does not work well, at least not like it was with the antenna windshield.
