Yet another Antenna Booster replacement (Dash removal post)
While researching the problem for poor radio reception using the good old SEARCH feature of this site, it had always returned the possibilities of:
1. Antenna lead from booster bad - small inner wire cut and requires reconnection.
2. Bad antenna booster (part # 964-645-173-00)
3. Bad Radio
4. Just sucks...deal with it
Furthermore related post almost always resulted in the question: "How do I remove the upper dash to replace booster?"
To help everyone with the location of the booster and dash removal I took some pictures when I replaced mine.
I'll update dash removal procedures later (actually someone here had a good description but no pics)
location of booster behind dash:
location of hidden 10mm nut (pic 1):
location of hidden 10mm nut (pic 2):
location of hidden 10mm nut (pic 3):
Clock removal suggest for easy access to nut (LHD):
2 notches in vent which need to be press down for removal:
Closeup:
Screws top off dash (under trim piece):
Location of screws under dash end trim piece:
Upper dash removed:
3. Bad Radio
Closeup:
Upper dash removed:
The dash is remarkably easy to remove - not the 1st time, though. And you don't cut your hand reaching through the alarm area. I used a wing nut in the "hidden screw" to make it easier. Turns out my antenna was loose - now I can get those stations I had given up on.
Sooner of later you'll need to remove the dash. My sealing foam was so brittle, it blew black dust. All the while, I was worried that black dust was oil and fanbelt particles being blown through a leaky heat exchanger. No leaky H.E. and now, no black dust. Also a good time to look for rust and window seal leaks.
What kind of aux antenna do you guys recommend? I did this dash removal today to see if I am connected properly. All seems well visually once I got the dash off (BTW) Thanks for the head's up on the nut near the clock.. I would have definitely done the same thing...
All wires seem okay.. but my radio reception is still pretty lousy.. are there alternatives?
Thanks..
--tcb
Thanks..
--tcb
Check the plug going into the radio- it's a VERY thin wire that if broken, will give you the weak reception. I tried to fix mine and got the plug too hot and badly deformed it. Bought a new antennae that is just waiting for time to put it in.
Professor of Pending Projects
Just updating the photos with ones link to rennlist... I have this saved for future reference and noticed the links no longer worked... hope that is ok with you puma1824.
Got them from your site
Thank you.
3. Bad Radio
Closeup:
Upper dash removed:
3. Bad Radio
Closeup:
Upper dash removed:
Thank you.
Patrik Rens (03-22-2021)
Thank you.
Thank you.
Thanks for letting me know. I updated my original post. BTW it's been a LOOONG time since I posted here. Miss my 964 Hope everyone is well.
bumping a old thread....
there are 3 wires coming out of the booster that aren't connected to anything. I have an aftermarket radio and wondering if they were forgotten or no longer needed? thanks.
