leaky bonnet
leaky bonnet
Hi All,
Recently tracked down cause of occasional damp carpet in front luggage compartment to the bonnet seal which doesn't contact the body very well right at the front - it's also turned a bit grey/white instead of black where it has lifted away. I've tried finessing seal to make it stay in position, but no luck. I'm assuming it's dried out a bit and is just a bit old.
Is this likely to need a replacement, or can I treat the seal in any way to bring it back to full functionality?
Cheers
Andrew
Cheers
Andrew
IHI KING!
I'm not a rubber restoration expert but its been my experience that once the rubber seals start leaking or cracking, that you need to replace them. Trying to do repairs is at best a temporary solution.
