Scantool Software & Interface from ecufix.com
I have an interface from www.ecufix.com and the scantool software and cannot get it to communicate. Can anyone assist?
I know my notebook is using COM 1 RS232 (no USB). My port settings are 9600, 8, none, 1 none. I see the echo, etc. LED's are gone as per the 964 and I am on the outside jumper, but nothing is happening. I can activate the adaptation button, but have not done so. I have tried the each of the ECU's AirCon, ABS, Montronic, etc. I have tested the cables for straight through. Nothing Nothing Nothing. I am stumped.
Any suggestions would be appreciated.
Burgled
I assume you have the ignition on or the car running. Attached are the plug in ports. I had to try 2 different 9 pin cables to get one to work. You might try that if you have another one.
Originally Posted by jimq
...I had to try 2 different 9 pin cables to get one to work. You might try that if you have another one.
Post edited...
The connector seems to be installed upside down in my car. Be sure to check the little numbers printed (molded) next to each connector pin in the car.
Below is the diagram I have used. This image is from Laurence Gibbs with a the lines/text darkened and an extraneous info removed. Here are the pin numbers we use:
P10-----GND
P7-------L line
P8-------K line
P12-----+12V (always hot)
(note P15 deleted, and drawing edited/updated to keep information correct, thanks Laurence Gibbs!)
P10-----GND
P7-------L line
P8-------K line
Last edited by Toddimus; 04-05-2007 at 02:48 AM. Reason: fix diagram/text after input from it's author, Laurence G
Correct Pin Layout
Unfortunately the ECUFIX circuit does seem to have a problem connecting. Most people have cut the two LED's or resistor R8 with success.
You definately need to make sure youre using a straight through serial cable and check you have the correct software. Make sure youre connecting to the right pins in the socket and if it still does not work then think about cutting the LED's.
Pin Layout
1. Airbag Gong Relay
2. Unused
3. Unused
4. Unused
5. OBC On/Off
6. Unused
7. L
8. K
9. Unused
10. Ground
11. Unused
12. Battery +VE
13. Ignition Power
14. Pin 6 of the DME, Rev Counter
15. Pin 22 of the DME, Check Engine Control On DME
16. Unused
17. Unused
18. Unused
19. Pin 21 of the DME, Knocking
I use pins 7, 8 ,10 and 13.
Hope this helps
Pin Layout
2. Unused
3. Unused
4. Unused
5. OBC On/Off
6. Unused
7. L
8. K
9. Unused
10. Ground
11. Unused
12. Battery +VE
13. Ignition Power
16. Unused
17. Unused
18. Unused
Hope this helps
Todd's drawing is correct - I've got the same printout in my glovebox for quick ref. Only thing is it's turned 90 deg to the left. So pins 10-12 are actually across the top of the connector (which then makes sense when you look at Jim's picture!)
one note for C4's, to connect to the PDAS I've found the following:
1. connect your +12V line to pin 12
2. ignition in run position but engine not started.
For whatever reason if my engine is running it won't connect to the PDAS. LIkewise, it won't connect if I put my +12V line into position 13 either (maybe related to engine running?)
Just for reference, my connector is rotated 180 degrees from the drawing I posted. I assume the the four mounting screws are are in a symmetric square, so it could be mounted 4 different ways. Conveniently, I can always remember which is ground, because it is closest to the ground (floor).
The picture of the amp socket was one i posted up. The faint pen markings are mine. if you use this for reference then IGNORE pin 15 as being switched ign it's NOT!!! I did put this in the original thread. I should have scrubbed out the offending pen mark.
I updated the drawing and edited my earlier post to reflect Laurence's input. Sorry I didn't give you credit when I first posted it. I just didn't recall who had first posted it. I copied the image long ago, and kept it on my hard drive. Heck, I even made a sticker with this image that I put on the outside of the project box in which my interface PCB lives.
Thanks again Laurence Gibbs for all of your efforts, as well as Gregg K and everybody who helped with the software and DIY interface.
Cheers,
Todd
Cheers,
Todd
