Maintainence Questions???
I want to keep my car in top condition and really let nothing go....
I could post several threads but I will try to keep my topics limited and simple.
I have NO idea when the last time my valves were adjusted..nor do I know that they need to be. I have owned 4 Pcars and this one sound as nice or nicer than the others but this does not mean adjusting is not necessary. I have some records but yjey do not draw a clear picture. So if I redo a procedure so be it. I am sure it will not hurt and I need the experience.
Can or does anyone have a file or something to go by to measure how a healthy motor should sound or how an unhealthy motor sounds?
Secondly...what else should I look at to bring this car to top condition as far as maintainence?
The next 6 months are going to be good weather and I want to do some of my own work to this car including some suspension work but bring her to top condition is my first priority and them upgrades.
What do you think?
What do you think?
IHI KING!
Brian,
You can't judge valve setting solely by sound\. If valve adjustments are looser than spec, you will hear extra clatter. However, if they are too tight, the valve train will be silent. Valves that are too tight are likely to burn. If you are in doubt of the valve settings, I would recommend you adjust them.
As for what other maintenance items you should do? It depends on how you are using the car. For street use, I have had good luck following the factory's maintenance intervals. If you are driving on the track or auto-crossing, then you need to use more frequent maintenance.
I posted a spreadsheet a while back with the maintenance requirements that I pulled from a couple of sources: Maintenance Schedule
