Sorry, ISV again
Sorry, ISV again
Hi all,
I've searched past posts and found something about being able to move the internals of the ISV with a screwdriver.
I took mine off last week and it looked fairly clean, but the internals will not budge.
Is this normal? and when I've finally got round to cleaning it should the internal movement move easily?
Rob
Rob
You are trying to move it the correct way? If I remember correctly - you can't lever it up from where the hole is, it actually moves the other way (if that makes sense).
Super Duper Moderator
Marc
Thanks guys
I was trying to move it the round way (I know what you meant Dave!)
Hooked up to a battery and it did flutter, just not all the way, the bit that moves had a lip on it so stopped when it hit the casing.
All sorted and sparkling now!
Rob
Rob
