964 Forum 1989-1994
harmonic balancer trivia question....
Old Feb 13, 2007 | 12:01 PM
garrett376's Avatar
garrett376
Question harmonic balancer trivia question....
I am curious if the harmonic balancer pulley on the crank is balanced to itself, or balanced to a particular crank, making them non-interchangeable between different engines.
My inclination is that it is balanced to itself, which would make the initial assembly much easier, but I wanted to make sure!!!
Old Feb 13, 2007 | 12:09 PM
Indycam's Avatar
Indycam
to itself.
If it was used to balance the crank , that would be crazy .
Old Feb 13, 2007 | 12:16 PM
garrett376's Avatar
garrett376
just checking... I thought I'd start the morning with an easy question
Old Feb 13, 2007 | 01:45 PM
Red rooster's Avatar
Red rooster
Its the rubber center thats the clue !
Even with a perfectly balanced crank etc a running motor produces harmonic resonances in the crank.
The rubber mounted pulley is used to counteract that effect .
All good stuff.
Geoff
Old Feb 13, 2007 | 02:47 PM
Indycam's Avatar
Indycam
"Its the rubber center thats the clue !"
Eh ?
The pully has been balanced by spinning it and then adding or removeing metal .
He was not asking whats the function .
Old Feb 13, 2007 | 03:17 PM
Red rooster
Indycam,
Sorry to have p*ssed you off !
Geoff
Old Feb 13, 2007 | 05:02 PM
darth's Avatar
darth
http://www.innerauto.com/Automotive_...onic_Balancer/
Old Feb 13, 2007 | 05:24 PM
Indycam's Avatar
Indycam
"Sorry to have p*ssed you off !"
I was not and am not pissed .
We are just talking about two different things .
Is the harmonic balancer pulley interchangable from crank to crank ?
Could you and I trade harmonic balancers without doing harm ?
Or is the crank / harmonic balancer pulley , ballanced as a unit ?
If the crank/pully were balanced as a unit , when we traded , we would be doing "bad".
Old Feb 13, 2007 | 06:09 PM
Red rooster
Indycam,
You are perfectly correct. The damper is a stand alone item. You would not want the damper from my motor as its a 993 !
All the very best
Geoff
Old Feb 13, 2007 | 06:31 PM
garrett376's Avatar
garrett376
Thanks guys... I wanted to be sure swapping pulleys between engines would not screw things up... now if I just had a torque wrench that went up to 174 ft/lbs!!!
Old Feb 13, 2007 | 06:50 PM
dfinnegan's Avatar
dfinnegan
Sears has one (944597 25 to 250 ft-lbs) that is reasonably priced. Though, I don't know if it's good enough for Porsche work!
Old Feb 13, 2007 | 07:01 PM
garrett376's Avatar
garrett376
My current one from Sears, has the Ft-lbs reading somewhere in the middle of the scale!! I can't tell if I'm at 30lbs, or 40lbs since the 0 reading ends up somewhere in the middle, not on the number exactly.... not a very good wrench! I need another one!
Old Feb 13, 2007 | 07:25 PM
Indycam's Avatar
Indycam
Red rooster / My Best Buddy and Pal
"You would not want the damper from my motor as its a 993 !"
Yes I do ! Please box up all the 993 parts that go with the pully and I will send you all the right 964 parts that I know you really should have . Yes thats right , your bad old 993 parts for my perfectly good 964 parts . I'm such a good guy , I will even pay for the shipping .
I'm going over to the post office now and wait there for the box , OK ?
Old Feb 13, 2007 | 08:22 PM
Red rooster
Indycam,
Your generosity overwhelmes me ! Wow, to think that a lighthearted remark during a break from work could lead to such an offer.
Unfortunately , I must decline your offer as I have got quite used to that 993 motor.
All the best with your search.
Geoff
Old Feb 13, 2007 | 08:25 PM
Indycam's Avatar
Indycam
Damn !
Now I'm pissed .
