964 Forum 1989-1994
harmonic balancer trivia question....
Old Feb 13, 2007 | 11:29 PM
DWS964's Avatar
DWS964
I recall when building engines of lesser precision (American iron from 40+ years ago) that when I had the engine balanced, I took the crank, harmonic balancer, flywheel,and pressure plate to the balancer. He would balance them as a unit, making adjustments in weight at various points. These engines were not balanced (much) from the factory, so balancing the rotating masses, checking rod and piston weights, etc. really made a difference in a smooth engine build. Now, I've stepped up to real engineering and construction.
Old Feb 14, 2007 | 07:58 AM
springer3's Avatar
springer3
Originally Posted by garrett376
... now if I just had a torque wrench that went up to 174 ft/lbs!!!
Weigh yourself. Stand the correct horizontal distance from the bolt on your cheater bar.
Old Feb 14, 2007 | 11:57 AM
Indycam's Avatar
Indycam
"Stand the correct horizontal distance from the bolt on your cheater bar."
I like this very very much . Never goes out of calibration , can't over torque .
Old Feb 14, 2007 | 12:58 PM
Red rooster's Avatar
Red rooster
Did I see a pair of torque setting shoes in WalMart the other day ? Maybe they were ice skates !!!
Geoff
Old Feb 14, 2007 | 01:41 PM
Indycam's Avatar
Indycam
Maybe up north thats the way you do it , but down south in yahoo land we use torque setting Stirrups ?
Old Feb 14, 2007 | 01:50 PM
Red rooster
Are the stirrups the sheep riding type or the apparatus involved with childbirth ??
Geoff
Old Feb 14, 2007 | 02:39 PM
Indycam's Avatar
Indycam
sheep riding ?
I think you have me confused with Bearclaw.
http://www.youtube.com/watch?v=LiQntJC-Efw
