964 Forum 1989-1994
Euro 964 C2 rear bumper vs 964 RS
Old 02-09-2007 | 04:54 PM
coupegr's Avatar
coupegr
Default Euro 964 C2 rear bumper vs 964 RS
Hi all.
I'm an old and fanatic reader from Spain. Now, I've changed recently my 911 from 3,2 to 964 C2 (but this is another history). And I am in the heat of phase a light restoration phase
Well, the question.
I've replaced the central part of rear bumper from standard C2 to RS. But, I think thats the holes for plate lights may be different.
It is clear, the external side for both supports are differents. But the doubt, the mechanized base in the bumper is usable for RS from C2 std?
Thanks from south of Spain.
Paco.
Old 02-10-2007 | 05:53 AM
108.5dba-static's Avatar
108.5dba-static
Originally Posted by coupegr
Hi all.
Well, the question.
Paco.
Hi Paco the rear lights on the RS are the same as those on the 3.2, not the 964.
You really need to fit the lights before you fit the bumper as they are a pig to get once its on.
As for the metal strip along the bottom of the bumper, yes it fits assuming you can get off the old bumper. I did not bother - saves a little bit of weight!!
Andy
Old 02-11-2007 | 03:23 AM
coupegr's Avatar
coupegr
Thanks Andy.
Saves a little bit of weight!!
When I've seen PET docs. the picture show like as my lovely 3.2.
But my doubt is about its drills for fits, because the new RS bumper has 3 drills and one square hole for each, fits 100% 964 stock lights plate.
And I think that true RS, it is not valid for this drills...
Regards.
Paco.
