So I'm changing my oil for the first time and...(long)
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by ilko
is it that the opening is not wide enough to hold the Great 911 Oil Flood?
![](http://forums.rennlist.com/upload/oildrainpan2.jpg)
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I WILL get a deep pan like the yellow one for sure (Thanks). That initial flow is what gets you. Can I take the other one back to the store now?
I did drill the hole in the filter and no drips...it works.
Pretty funny when I came in proclaiming I just saved 100 bucks for doing my own change...after spending all day doing it. Didn't get the cheers I was expecting...
I did manage to keep the transaxle fluid in there..I think?
Adam
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Adam
Technical Guru
I bought one because it said it was 15 quarts I think, which should be more than enough.
I think the risk of shards from drilling is low... any that fall inside the filter should fall onto the sticky (oily) filter media, and if any should flow back toward the crankcase they'll just get picked up in the new filter.
To each his own.
To each his own.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Just leave the drain plug open when you pull the filter and there is no mess.
I had the constantly flowing filter the first time around. With the drain plugs open there was no mess at all. No need to risk the metal bits in the oil flow.
Mada1
as you might guess from the posts there is more than one way to skin a cat and there are opinions on the same method.
Just be glad you did not ask about the proper sealant to use when putting case halves back together.
If you punch the oil filter, punch the top, then prior to removal, place a piece of masking tape over the hole so you wont leak any oil that may be there when you screw it out. I would just use a phillips screwdriver and punch it smartly.
Professor of Pending Projects
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Originally Posted by stevepaa
Mada1
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
